How to enable CVP Datafeed loggers for VXML Apps
hari.kanan Mon, 09/14/2009 - 07:35
CVP data feed loggers are enabled by default.
if u have disabled it then you need to make the changes on settings.xml and include the cvp datafeed XML String.
Make sure you update the application by running the update.bat file.
