ASA 5505 VPN NAT
dkirks
Hi all,
I am working with an ASA 5505 and am trying to get remote VPN working. I used the wizard to set up the connection and I can connect to the appliance. When I do connect, I cannot do anything, like surf, nslookup, access the ASDM, etc. I think NAT is where I need to be looking and I have tried NAT exempt rules with no luck. Can anyone help with this?
JORGE RODRIGUEZ
Level 10
Level 10
You need this ( if doing full tunnel ra vpn)
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805734ae.shtml
example
same-security-traffic permit intra-interface
global (outside) 1 interface
nat (outside) 1
as for accessing ASA through RA tunnel or any ipsec tunnel you need couple of statements:
management-access inside ( provided your inside interface nameif is inside)
http inside
telnet inside
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/m.html#wp1987122
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
example
nat (outside) 1
http inside
telnet inside
Jorge Rodriguez
Thanks so much!
