CUCM transcoding. DSP farm adds to or replaces software DSP ?
Answered Question
Sep 14th, 2009
I have a CUCM 6.1. My understanding is that this has 48 MTP sessions running in software?. If I connect the CUCM to an external DSP farm will the resources available on the farm be added to the existing MTP resources or replace them? Thanks.
Correct Answer by Jaime Valencia about 7 years 10 months ago
You'll need to configure the MTP or XCODER into the MRG for devices to use it.
But you can configure SW MTP + HW to get a total of X sessions
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Mon, 09/14/2009 - 06:47
  • Cisco Employee,
  • Hall of Fame,
    2011
java
