Unity Express
Answered Question
Sep 14th, 2009
I have a Unity Express running on a Call Manager Express that the MWI is not working correctly. The CME had it's IP changed, not the Unity, but calls are still pushed to Unity and users are getting the voicemails. Just MWI is not working correctly. What can I look for within the CME or UE to check why?
Correct Answer by Rob Huffman about 7 years 5 months ago
Hi Arthur,
There are some good tips in this guide;
**Cisco Unity Express points to the correct Cisco CallManager Express server IP address. The show ccn subsystem sip command shows this.
Troubleshooting Unity Express Message Waiting Indication (MWI) Problems
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008027fa9f.shtml
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 09/14/2009 - 07:50
Hi Arthur,
Hope this helps!
Rob
Nicholas Matthews Mon, 09/14/2009 - 10:43
Log into the router and look at the servicemodule interface. It should have a command like "service-module ip address x.x.x.x 255.255.255.255" for example. That's the address.
-nick
a.gooding Mon, 09/14/2009 - 11:17
once you can login into the cue as pointed above you can also go into the cue GUI and do a resynchronise.
arthurbecker Mon, 09/14/2009 - 11:52
OK, It looks like a found the issue. i need to change the SIP gateway IP address to point to the correct CME.
xx-xx-xx-xx-57> show ccn subsystem sip
SIP Gateway: 10.168.1.56
SIP Port Number: 5060
Do is just do a confg T and do I need to reboot the CUE as well?
a.gooding Tue, 09/15/2009 - 10:02
Glad to know you got it sorted, sorry couldnt reply after my initial post. Also, if possible, to help others, could you describe your fix in case anyone else comes into this problem in the future?
thanks once again.
