wireless express access point
Sep 14th, 2009
My question is with the 521g(lighweight) acess point using the 526 wireless express mobility controller do you still need to run cat5 to the wireless access point? or is there just a power injector used and the wireless is controlled through the controller to each access point?
Steven DiStefano Mon, 09/14/2009 - 08:11
Each AP521 in LWAPP mode should be connected to the UC520 / UC540 to one of the POE switch ports (or a POE Switch switch port connected to the UC500 expansion port) with Smart Port Role set to AP.  The WLC526 connects the same way with the same switch port role.
