Device Discovery
Sep 14th, 2009
Can I tell CiscoWorks not to discover non Cisco devices? It appears that my LMS3.0.1 on solaris10 is discovering bunch of Hp switches and silver peak WAN accelerator which as a result fail in the archive in RME.
Joe Clarke Mon, 09/14/2009 - 08:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can enable Discovery filters to exclude these IP addresses. If you use exclude filters, the devices will not be contacted by Discovery.
nawas Mon, 09/14/2009 - 08:25
Yes, I knew this method but is there any simpler method than that? I have tons of IP addresses that I will need to enter. But why CiscoWorks will discover non-Cisco devices? Is used to not do that.
Joe Clarke Mon, 09/14/2009 - 08:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It always did if the devices support CDP. You could use a SysObjectID filter instead of IP Address filter, then exclude the sysObjectIDs of the HP devices.
nawas Tue, 09/15/2009 - 06:43
Is there a way to specify a .csv file for device discovery filter? Can I use a combination of IP address and SysObjectID in the device discovery filter?
Leo Laohoo Mon, 09/14/2009 - 18:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
CW will "discover" if you have the right credentials: SNMP, IP addressing, etc.
What I do is import from a text file (.csv) the IP address of the new devices.
