WAE Edge is showing offline
Sep 14th, 2009
Hi All
I have a design where all my WAE are inline in the path of traffic .
One of my WAE Edge shows on the CM as offline and after half an hour it comes online , again it went offline after 1 hour and so on.
What might be the issue and when its offline I can not even remotely telnet to the management intrerface of WAE but its keep on by passing the traffic.
Any body face the same issue , the problem with hardware or any suggestion.
asfar.zaidi Tue, 09/15/2009 - 07:46
Very interesting finding
1- Branch WAE Edge status on CM GUI is offline.
2- Unable to telnet Branch WAE Edge remotely.
BUT
1- Able to telnet Branch WAE Edge from the local netwrok.
2- When I telnet and check the cms info of Branch WAE Edge its showing 'inline'.
3- Branch WAE Edge is intercepting the traffic and optimizing and accelerating the traffic.
Any body can shed light on this issue why I am getting status off line on WAAS CM for this Branch WAE Edge.
asfar.zaidi Tue, 09/15/2009 - 10:16
Just to provide all experts and viewers more insight to the problem
my Branch WAE Edge is Cisco WAVE-574-K9 Platform running with WAAS version 4.1.1c (build b16 Nov 5 2008) software.
