SNMP Commands on 7206VXR
Answered Question
Sep 14th, 2009
Hi Gurus,
What is the equivalent command for 7206?show snmp mib ifmib ifindex
Thanks.
Jeff
Correct Answer by Giuseppe Larosa about 7 years 7 months ago
Hello Jeff,
I can confirm your problem I've tried on an older C7206
sh ver | inc image
System image file is "slot0:c7200-is-mz.121-25.bin"
And it doesn't accept the command
The only other way I know is by using an SNMP MIB browser
and using OID
.iso.org.dod.internet.mgmt.mib-2.interfaces.iftable
looks for lines with
ifEntry.ifDescription
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 09/14/2009 - 08:30
  • Hall of Fame,
    Founding Member
hello Jeff,
it should work also on C7200 it may require enable
NVI0: Ifindex = 10
Null0: Ifindex = 7
SSLVPN-VIF0: Ifindex = 6
VoIP-Null0: Ifindex = 5
Loopback10: Ifindex = 8
Loopback100: Ifindex = 11
Loopback20: Ifindex = 9
GigabitEthernet0/1: Ifindex = 1
FastEthernet0/2: Ifindex = 2
GigabitEthernet0/2: Ifindex = 3
GigabitEthernet0/3: Ifindex = 4
Loopback172: Ifindex = 12
sh ver | inc image
System image file is "disk2:c7200p-advsecurityk9-mz.124-20.T.bin"
if it is not supported in your device it is a question of IOS image
Hope to help
Giuseppe
jeffersoncbriones Mon, 09/14/2009 - 08:35
Hi Giuseppe,
That explains why i dont get this command. Is there any work around? I want to check the index for my Gig1/0 interface.
#sh ver | include image
System image file is "disk0:c7200-js-mz.122-13.bin"
Thanks.
Jeff
Correct Answer
Giuseppe Larosa Mon, 09/14/2009 - 08:42
  • Hall of Fame,
    Founding Member
Hello Jeff,
sh ver | inc image
and using OID
Hope to help
Giuseppe
