IOS 2950
Sep 14th, 2009
I need create class-map in the Cisco Switch 2950, but I dont can create it. I upgrade the IOS. The Ios running in the Switch is the following:
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA13, RELEASE SOFTWARE (fc2)
BOOT path-list: flash:/c2950-i6q4l2-mz.121-22.EA13.bin
I read the paper :
Catalyst 2950 and Catalyst 2955 Switch Software Configuration Guide, 12.1(22)EA2
But the version 12.1(22)Ea2 is available ??
Overall Rating: 3 (1 ratings)
glen.grant Mon, 09/14/2009 - 09:49
  • Purple, 4500 points or more
It depends on what model of 2950 it is , if its a standard code box or enterprise box . If standard box then QOS may have limited availibilty . To define QOS parameters you must have the EI code which is model dependent. All code is the same for these boxes but the code has enough intelligence to know what box it is being loaded on , if your 2950 is not an EI box then class maps may not be available. A show version will tell you if it's a EI or standard box.
ricardorojas123 Mon, 09/14/2009 - 11:30
That is my output show version:
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 27-Feb-09 22:20 by amvarma
Image text-base: 0x80010000, data-base: 0x80570000
ROM: Bootstrap program is C2950 boot loader
Switch uptime is 19 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA13.bin"
cisco WS-C2950-24 (RC32300) processor (revision R0) with 20957K bytes of memory.
Processor board ID FOC1009
Last reset from system-reset
**Running Standard Image**
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: ommited
Motherboard assembly number: ommited
Power supply part number: ommited
Motherboard serial number: ommited
Power supply serial number: ommited
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: ommited
Configuration register is 0xF
ricardorojas123 Mon, 09/14/2009 - 11:35
The output of the show : **Running Standard Image**
I can upgrade IOS to Enhanced Image or the hardware do not support the Enhanced Image?
Lucien Avramov Mon, 09/14/2009 - 11:45
  • Red, 2250 points or more
Check the Image requirements on the download page.
You may have or have not access to advanced / enhanced images as it depends on your support contracts.
ricardorojas123 Mon, 09/14/2009 - 13:17
I upgrade the IOS with this file : c2950-i6k2l2q4-mz.121-22.EA13.bin
And the Standard Image is enabled in the Switch ... :(
cisco WS-C2950-24 (RC32300) processor (revision R0) with 19912K bytes of memory.
Processor board ID FOC1009Z3QK
glen.grant Mon, 09/14/2009 - 14:11
As I said before it is platform dependent and yours is running standard version so it cannot be upgraded.
Leo Laohoo Mon, 09/14/2009 - 14:33
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The basic 2950-24 is an Standard Image (SI) only switch. Some of the Gig uplink ports, such as the 2950G, supports Enhanced Image (EI).
