LS1010 / Catalyst 8500 MEMDIAG_NVRAM_MAGIC_PATTERN_DATA_ERROR
Sep 14th, 2009
What does the error when you display power-on diagnostics mean when it says:
M4:Non-Volatile Memory Read/Write Test []
*** MEMDIAG_NVRAM_MAGIC_PATTERN_DATA_ERROR *** [Addr:BE001008, exp:0000ABCD, act:00000000]
power-on Diagnostics Passed.
This is on a L1010 with FCPFQ and no config on it.
Giuseppe Larosa Mon, 09/14/2009 - 10:38
  • Hall of Fame,
    Founding Member
Hello Brian,
the device has failed a memory test, however the overall result is passed.
Depending on the use you can ignore this if it is for a lab for example.
Hope to help
Giuseppe
bfeeny Mon, 09/14/2009 - 10:39
Thanks, doing some further testing it seems this may be the normal result when you "wr mem". Once any sort of config is on the FCPFQ it seems to go away.
