poe
Sep 14th, 2009
Good morning, my name wilian and I'm having problems with my 3560 switch ps, because he is in error on port poe. here's the boot.
POST: PortASIC RingLoopback Tests: Begin
POST: PortASIC RingLoopback Tests: End, Status Passed
POST: Inline Power Controller Tests: Begin
POST: Found inline power controller write failure, inst 0
POST: Inline Power Controller Tests: End, Status Failed
POST: Inline Power feature is disabled on this switch
POST: CAM Subsystem PortASIC T
POST: PortASIC CAM Subsystem Tests: End, Status Passed
POST: PortASIC Port Loopback Tests: Begin
POST: PortASIC Port Loopback Tests: End, Status Passed
Waiting for Port download ... Complete
do not know what else to do her work. if anyone knows I thank you resolve
Edison Ortiz Mon, 09/14/2009 - 10:43
Wilian, you have a hardware problem and the only solution is contacting TAC for a RMA.
__
Edison.
Leo Laohoo Mon, 09/14/2009 - 14:46
Kindly contact Cisco and raise a TAC.
gudao_77@ Wed, 09/23/2009 - 09:55
I have a cisco 3745 equipment you 2Fe and my T1/E1 card and most do not think my board on the island and that this software has equipament OS (tm) 3700 Software (C3745-IS-M), Version 12.3 (19), RELEASE SOFTWARE It is compatible with this card voip?
Paolo Bevilacqua Wed, 09/23/2009 - 15:44
I think a inverse online translator would a great invention for the Internet.
Perhaps that would help us understand what a T1/E1 card has to do with the island.
gudao_77@ Thu, 09/24/2009 - 07:55
I have an equipment Cisco 3745-lo-2fe and am having problems with mine I modulate t1/e1, in the console it not appears
Leo Laohoo Fri, 09/25/2009 - 18:03
Let me see if I can understand your issue.
You have a 3745 and you are having problems (like configuration) of a T1/E1 module. Am I getting closer to your issue?
If this my understanding is close enough, can you provide more information?
What is the complete product ID of the E1/T1 module?
What is the IOS of the 3745?
