Default Ringtones & Distinctive Ringtones
Sep 14th, 2009
We're running CUCM 7.1, and we've narrowed down a list of "acceptable" ringtones for the company. Fortunately the boss picked Chirp1&2 as one of the acceptable rings... however when we go to roll out the XML files to adjust the ringtones (RingList.xml and DistinctiveRingList.xml), it works great! Chirp1&2 are avail for the "default ring" - but I can't set these rings to the distinct lines. I don't know how to add these rings to the DistinctiveRingList.xml either... any help would be greatly appreciated, thanks!
Eric Krieger Mon, 09/21/2009 - 23:59
Hi Scott,
Chirp 1 & 2 are both ringtones built-in the phone (hardware/firmware), and as far as i am aware off you're not able to add them in the DistinctiveRingList.xml, nor remove them.
Regards, Eric
arrrghhh3 Tue, 09/22/2009 - 07:12
So I can only set these two rings as the default ring, I can't set them to a specific line? That seems... uhm for lack of a better word, insane?
