is-is requirments
Sep 14th, 2009
Hi, I am taking BSCI course. I am try to find minimum requirement to run isis on old 2600 routers I have for a lab. I have been looking around Cisco's site, searched is. Can find a lot of info about is but not requirements to run. I can enable router isis but it will not accept network command. Below is what my routers have.
Thanks, Doug
System image file is flash:aaa0224.bin
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Giuseppe Larosa Tue, 09/15/2009 - 02:07
  • Hall of Fame,
    Founding Member
Hello Doug,
I would be surprised if it would be supported:
IS-IS doesn't use network command
on interface configuration where you want to run is-is use
int type x/y
ip router isis
do it on all interfaces including loopbacks
Hope to help
Giuseppe
REDDOUG53 Tue, 09/15/2009 - 15:57
Setup from lab book;
router isis
net 49.0001.1111.1111.1111.00
int fa0/0
ip router isis
After I enable isis on the router, when I try the next line is were I have my problem. I get ^ under net as unrecognized command.
Thanks, Doug
Laurent Aubert Tue, 09/15/2009 - 18:31
  • Cisco Employee,
Hi Doug,
I saw you have only 8M of Flash so you can use only 12.0 version but you need service-provider or enterprise-plus feature pack which both require 24M of RAM.
Laurent.
REDDOUG53 Thu, 09/17/2009 - 15:04
Thanks for the info. Would you know where I could find that kind of information? I have been looking over Cisco's site. I am thinking it is because it is older not much ifno is available.
Doug
Giuseppe Larosa Wed, 09/16/2009 - 02:32
  • Hall of Fame,
    Founding Member
Hello Doug,
in some old releases like 12.0 you need to enable clns routing to use the net command because the net is actually a CLNS address given to the node.
try
conf t
clns routing
router isis
net
This should help
hope to help
Giuseppe
