09-14-2009 11:35 PM - edited 03-15-2019 07:44 PM
I am running CME 7.1 IOS 12.4(24)T1 on a 1861 router and have the following issues I need some help with.
1. I have 5 extensions numbers 8820 - 8825 with 8820 being the main number. The problem is that when you place a call from 8821, 8822 etc... that outgoing DNIS is the 8820 extension. I need all extensions to use their own extenion when dialing out (8821 will use 8821 etc..) . I have 20 DDI's reserved from the telco 8820 - 8840.
2. I have 2 BRI ports however only port 0/1/0 works, port 0/1/1 doesn't, so instead of having 4 lines to use I only have 2 - am I missing something from my configuration ?
Your help as always appreciated.
thanks
Rod
09-15-2009 12:04 AM
1. You need a translation-rule, or dialplan-pattern. I always recommend the first.
voice translation-profile makenum
translate calling 10
voice translation-rule 10
rule 1 // /012345/ <--Thats is the portion of number before 8820
trunk-group bri
translate outgoing makenum
voice-port 0/0/0
trunkgroup bri
This also introduces you to the use of trunkgroup, to be referenced instead of port in the DP to simplify configuration.
2. Use isdn static tei 0 for the BRI not working now.
09-15-2009 12:15 AM
Thanks P.
I will test it out in the next 2 days when I go to site.
I used the isdn static tei 0 command on the interface that didn't work which resulted in no calls being allowed through the CME - all I got was a dead tone.
Will get back to you when I have a chance to make your suggested changes.
Thanks again
Rod
09-15-2009 12:17 AM
It must be TEI 0 - there is no other alternative.
Ask if something I wrote is not clear, I put the condensed version.
09-21-2009 02:04 AM
Hi P.
I am using the following config:
When I dial out from x 8820 to 01925858218 and do a sh isdn active for the calling number it shows a .
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out . +1925858218 7 0 0 0
Also I configured bulk speed dial as per one of our previous conversations which workes fine - thanks, however I have another issue.... I have configuread telephone service to contact the remote UCM 7 server for directory servies and when the user looks up an entry on the server and dials it they get a engaged tone - this is probable down to no translation profiles being configured for outgoing calling numbers ??? is that correct?
Rod
09-21-2009 02:10 AM
Take "debug isdn q931" with "term mon" to diagnose calling issues. Seem like you've no other major problems.
09-21-2009 02:26 AM
09-21-2009 02:31 AM
Call show as connected, but it's very strange the same message is received on both interface.
You may have a cabling issue before or after the NT1 boxes, ask telco to check.
09-21-2009 02:48 AM
Hi P.
Rod
