mpls pe and p function one the same device
Sep 14th, 2009
Hello ,
Is it possible to configure mpls pe and p functions on the same router ? This router will run as p device for some connections and it will run as pe device for another connections. Could you give me information about this situation ? Kind Regards...
Burak
Giuseppe Larosa Tue, 09/15/2009 - 02:02
  • Hall of Fame,
    Founding Member
Hello Burak,
this is possible.
a device is a P node if it is in the middle of an LSP.
It is a PE node or an edge LSR if it is the interface with outside world (out the MPLS cloud).
to be a PE the node has to take part in MP BGP.
Hope to help
Giuseppe
