ADSL Config Advice
hellspire69_2
Apologies in advance if this question has been asked before.
I have recently purchased a 877 router and have been delegated the task of configuing it for ADSL2 connectivity, the problem is router config side i havent a clue!! :) could anyone give me advice on documentaion or point me in the right direction to get this up and running?
Daniel
paolo bevilacqua
First ask SP about the connection data (VPI/VCI), username/password (if PPPoE).
Then there are many examples, use the search box top right corner.
Ian Cowley
Daniel
We have deployed several hundred 837/857/877 routers is UK with aggressive ACLs and INSPECT.
more than happy to help, but will need more info
email me direct if you wish
