WAAS cabling
Sep 15th, 2009
The customer will use WAE with inline card between a router and LAN switch. There is a switch module in the router. Tha WAE will be connected into a port on the switch card (HWIC-4ESW) and into a port on the LAN switch. The both ports are FastEthernet. Can I use the straight-through cabel for both connections (WAE into the router and WAE into the LAN switch)? Thank you.
