access point issue - not forwardiing arps etc
Sep 15th, 2009
Hi all
I dont know if anyone on here can help, I have an AP setup to connect to a workgroup bridge, the wgb then plugs into a pc. Now whats happens is for some reason the pc is sometimes unpingable, but when I jump on the ap that is plugged into and run a ping, it pings ok, This then brings back to life the ping from the lan.
Anyone got any ideas what this could be ?
iyde Thu, 09/17/2009 - 12:32
Hi Carl.
Is the AP an autonomous (Aironet) AP or a lightweight AP (Airespace; LWAPP)?
If it is the latter, a colleague of mine has just ahd a case where the WGB lost the ARP entries for the client on the ethernet port, if the client did not periodically initiate data transmission by itself.
HTH.
carl_townshend Fri, 09/18/2009 - 00:17
Hi There
how come this would affect it? as the ap shouldnt need arp entries, just a mac entry?? it sounds like the same thing, was there a workaround to this ?
