09-15-2009 05:04 AM
Hi all,
As far as I've read, netflow on C4500 should be globally configured by entering : ip flow ingress infer-fields.
Ok, but if I enter tis, what exactly the switch will do ?
My goal is to simply monitor the traffic from a port of this switch to the Firewall. (LAN to outside traffic)
But if the CPU o switch goes crazy because it's processing too much traffic, is there any other possibility to do this ?
If someone could light my mind, I'd really appreciate :))
Thanks in advance for your support
Olivier
Solved! Go to Solution.
09-15-2009 05:46 AM
Hello Olivier,
Once you configure netflow on your switch, switch collects traffic statistics about the packets that flow through the switch and stores the statistics in the NetFlow table. You can view these stats on switch itself or you can export this data to Station running Netflow collector software to view in graphical manner. There are other options such as ip accounting(not supported on 4500) and NBAR which you can use to collect traffic stats depeding on they are supported by your platform or not. As you have identified, Netflow process is bit cpu and memory intensive and usually gives around 2-5% extra load on your cpu. So depending on your current usage you should decide whether to use netflow or not.
Also note that Netflow is supported on 4500 platform depending on supervisor and image you are running. Supervisor Engine 6-E and LAN base image do not support Netflow.
For configuration help refer:
09-15-2009 05:46 AM
Hello Olivier,
09-15-2009 06:02 AM
Hi yagnesh,
Thanks for your reply. I have 2 Supervisor Engine cards V-10GE, so it seems OK.
CPU is running around 48% of load average, I hope it's OK too :))
I'll enable it and let see what happens :)
Thanks again !!!
Olivier
