Nexus 5020 and 1Gbps connections
Sep 15th, 2009
I'm having problems connecting 1Gbps interfaces (just a simple autonegotiating 1 Gbps Laptop) direct to a Nexus 5020 port. I'm using a GLC-T in one of the ports that supports 1 Gbps (ports 1-16), and I've configured the speed to 1000.
The link tries to come up for a fraction of a second (by looking at the laptop port)then drops.
I've tried several ports and a couple of different GLC-T SFPs, and I'm using the latest software (n5000-uk9.4.1.3.N1.1.bin). I've even tried fixing negotiation, using a crossover cable, but no luck. Does anyone have any suggestions or know if this is a known problem?
Darryll
Yudong Wu Tue, 09/15/2009 - 11:59
  • Gold, 750 points or more
can you post the following when the link is in down state?
show interface x/y
show interface x/y trans
show system internal ethpm event-history errors | grep x/y
darryll.plumb Tue, 09/15/2009 - 12:03
Thanks, I'm off-site at the moment, but I'll get the information to you tomorrow
darryll.plumb Wed, 09/16/2009 - 03:30
Output from the switches below
CPLUKLONNXS0001# sh int eth 1/1
Ethernet1/1 is down (Link not connected)
Hardware: 1000/10000 Ethernet, address: 000d.ecb4.dac8 (bia 000d.ecb4.dac8)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Encapsulation ARPA
Port mode is trunk
auto-duplex, 1000 Mb/s, media type is 1/10g
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
Last link flapped never
1 minute input rate 0 bits/sec, 0 packets/sec
1 minute output rate 0 bits/sec, 0 packets/sec
Rx
0 input packets 0 unicast packets 0 multicast packets
0 broadcast packets 0 jumbo packets 0 storm suppression packets
0 bytes
Tx
0 output packets 0 multicast packets
0 bytes
0 input error 0 short frame 0 watchdog
0 no buffer 0 runt 0 CRC 0 ecc
0 overrun 0 underrun 0 ignored 0 bad etype drop
0 bad proto drop 0 if down drop 0 input with dribble
0 input discard
0 output error 0 collision 0 deferred
0 late collision 0 lost carrier 0 no carrier
0 babble
0 Rx pause 0 Tx pause
0 interface resets
CPLUKLONNXS0001#
CPLUKLONNXS0001# sh int eth 1/1 trans
Ethernet1/1
sfp is present
name is Methode Elec.
part number is SP7041
revision is A
serial number is MTC009044
nominal bitrate is 1300 MBits/sec
cisco id is --
cisco extended id number is 4
CPLUKLONNXS0001#
The grep 1/1 output of the show system internal command didn't return with any output. I have added an attachment with the command without the grep command
Yudong Wu Wed, 09/16/2009 - 13:41
Yours SFP looks OK. In general, we will see "SFP validation failed" under "show interface". I validated its SN as well.
Can you try the following?
1. "speed 1000" must be configured.
2. try a different cable.
3. hard code your laptop seed to 1gig
4. upgrade laptop NIC driver
5. try a different laptop.
If the above still does not help, please open TAC case.
darryll.plumb Thu, 09/17/2009 - 00:14
Thanks for Validating the SN for us. We have tried all of the tests above, and also tried cross-over cables, a couple of SPF, and connection to a 3750 switch on site. None of these have worked for us, in all cases the link comes up for a fraction of a second then fails, so we are going to raise a TAC case .Thanks for the response. If I get any resolution I will post it here.
