Warning message
LMS 2.6/CS: error message when tring to add device to master
Answered Question
Sep 15th, 2009
Customer has an error message when he try to add a device on a master LMS 2.6
It use to work find, here you can find a screen shot.
Elisabeth
Correct Answer by Joe Clarke about 7 years 11 months ago
As I said, the two servers have different MDF versions. The slave has 1.24, and the master has 1.22. On the both servers, go to Common Services > Software Center > Device Update, and check the box next to Common Services. Download and install the available updates. That should bring you up to MDF 1.28 on both servers, and this problem should be fixed.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 09/15/2009 - 06:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the output from the pdshow command from this server. What version of RME is this server running?
Joe Clarke Tue, 09/15/2009 - 11:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The service startup parameters have been changed. Post a screenshot of the Services control panel showing all of the CiscoWorks services.
ebezombes Wed, 09/16/2009 - 05:01
You can find the cw service screeshot.
I have asked to the customer to change both services to manual:
- CiscoWorks Tomcat Servlet Engine
- CiscoWorks Web Server
She has reboot the server but she still have the same issue.
Elisabeth
Joe Clarke Wed, 09/16/2009 - 07:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the new pdshow output and the NMSROOT/MDC/tomcat/logs/stdout.log.
Joe Clarke Wed, 09/16/2009 - 09:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The master and slave have different MDF versions, and this is causing the problem. Make sure both servers have the same MDF Common Services package loaded, and this error should go away.
Joe Clarke Thu, 09/17/2009 - 07:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the NMSROOT/lib/classpath/com/cisco/nm/cwcs/mdf/mdfdata.xml file from both servers.
Correct Answer
Joe Clarke Thu, 09/17/2009 - 22:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ebezombes Tue, 09/22/2009 - 06:59
Cu has installed MDF 1.28 on both servers, now it's working !
Why two different version can produce this issue ?
Thanks a lot for your help Joe !
Joe Clarke Tue, 09/22/2009 - 07:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If a device does not have a corresponding MDF entry on a local machine, then this error will occur.
