09-15-2009 06:40 AM - edited 03-06-2019 07:43 AM
I have 2 Catalyst 3750 switches. And I need to connect them accordng to this scheme (see an attachement). I also attach parts of configs and ping's listing.
What have I done wrong?
Solved! Go to Solution.
09-15-2009 07:15 AM
Hi Andrey,
Perhaps command 'interface bvi bridge group' is not supported even though switch may accept it without giving any error. You can confirm this by checking configuration guide of your code. Look into section 'Unsupported Commands'
If that's the case than you can configure SVI interface instead and assign it with IP address and bridge group.
09-15-2009 07:15 AM
Hi Andrey,
09-15-2009 08:47 AM
Have a look at this doc. This is the only type of bridging supported on the 3750.
09-15-2009 10:06 AM
Thank you! This feature is actually unsupported in my image.
09-15-2009 09:26 AM
Hello Andrey,
as Glen has pointed fall-back bridging for ipv4 traffic is not supported on C3750.
in simple words the command
bridge 1 route ip
is not supported the device attempts to route it but without using IRB.
if you don't want to join the STP domains use point to point L3 links.
Hope to help
Giuseppe
