IVAD circuit and cisco 2801
Hi all - I'm considering purchaing a telepacific IVAD circuit that will allow me to run voice and data over their T1. I've got a 2801 router w/ CME that I'm using with a traditional PRI terminating in a T1 controller. Does anyone know if the IVAD circuit, which I'm told has an RJ48 handoff, work with my gear? Thanks,
-matt
paolo bevilacqua Tue, 09/15/2009 - 08:12
  • Hall of Fame,
    Founding Member
Can you ask telepaciic what exactly IVAD is and how do they split voice and data ?
Consider if you currently got PRI and IVAD work with CAS, you would loose features.
