catalyst 6509
I have a 6509 with 2 WS-X6K-SUP2-2GE sup engines. The one in slot 0 does not show up anymore and slot 1 is active. When doing a show mod slot 1 shows supervisor-other unknown and when sh redundancy shows standby down. They are both running c6sup22-jsv-mz.121-26.E8. The unknown sup engine in slot 1 keeps reloading, decompressing the image and then says it is standby and then reports changing console ownership to route processor and then in a few minutes reloads again. Any ideas? Is my sup engine card hosed?
rducombl Tue, 09/15/2009 - 08:27
  • Cisco Employee,
IT is hard to say.
If you can connect to console try :
- insert a flash card in it
- Connect to console
- break it to Rommon
- Try to boot it with another image.
it might also help to see the complete console log when it is booting in cycle ? Also do you see any syslog message on the active sup when the standby is reloaded in cycle ?
Thnaks,
Roland
here is the logging entry from syslog: 30w4d: %ONLINE-SP-6-TIMER: Module 1, Proc. 0. Failed to bring online because of timer event
30w4d: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
Attached is the console log....it says there is corrupt nvram which is a new error that it didnt report before.
Lucien Avramov Tue, 09/15/2009 - 11:19
  • Red, 2250 points or more
This sounds like an RMA.
Are you able to try this SUP in another chassis or slot?
If you were able at least to boot it, I would have recommended to format NVRAM: first before concluding it's a bad module.
Try another slot to confirm it's not related to the backplane.
