IPMA 2 managers 2 assistant
Sep 15th, 2009
Hy,
I configured IPMA with proxy line on CM 7.0
I configured 2 managers.Each manager with 1 assistant.Everything works fine but i want assistant can call just the associated manager.
It 's possible to configure assistant to call just the associated manager?
Thanks.
trienguy Tue, 11/03/2009 - 21:24
yeap you can do that by using
Two Partitions
Manager 1 = P_Manager1
Manager 2 = P_Manager2
Make sure your IPMA CSS has both partitions
The CSS_Assistant1 should only contain the P_Manager1
This would work but the design going to be messy if you have more than 20 managers in a network..
