problem with mgre nhrp
Answered Question
Sep 15th, 2009
I'm trying to set up a gre tunnel between a spoke router with dynamic ip, and a hub router with fixed ip. And it doesn't work.I am using a loopback interface of de hub router as the destination tunnel ip in the spoke router. May be the problem that no use an ip of phisical interface?
Thanks.
Correct Answer by paolo bevilacqua about 7 years 8 months ago
IPsec supports dynamic peers, it's all in the documentation.
We also used EzVPN, that works better in presence of NAT.
As mentioned, I have DMVPN without tunnel protection, works fine.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Tue, 09/15/2009 - 12:10
  • Hall of Fame,
    Founding Member
For that to work, you need to configure IPsec first, in practice it's a DMVPN setup.
MARCELO MATURO Wed, 09/16/2009 - 04:32
I did this. The configurations are:
hub:
interface Tunnel100
description Tunel a router 3G
ip address 77.6.248.30 255.255.255.252
no ip redirects
ip nhrp authentication test
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 600
ip tcp adjust-mss 1260
tunnel source loopback10
tunnel mode gre multipoint
tunnel key 10000
tunnel protection ipsec profile 3G
spoke:
interface Tunnel100
ip address 77.6.248.29 255.255.255.252
ip nhrp map 77.6.248.30 192.168.35.113
ip nhrp map multicast 192.168.35.113
ip nhrp holdtime 300
ip nhrp nhs 77.6.248.30
tunnel source Cellular0/2/0
tunnel destination 192.168.35.113
tunnel key 10000
The ipsec is up. There is an isamkp SA established.
Thanks.
paolo bevilacqua Wed, 09/16/2009 - 11:21
  • Hall of Fame,
    Founding Member
Check that you can ping between the tunnel source and destination.
Then, a /30 mask seem from for multipoint tunnel.
Also, I would not use tunnel protection, configure ipsec independently.
MARCELO MATURO Wed, 09/16/2009 - 12:36
The ping is ok in both sides. I modified de mask in the hub, but it doesn't work.
Thanks.
Correct Answer
paolo bevilacqua Wed, 09/16/2009 - 12:37
  • Hall of Fame,
    Founding Member
MARCELO MATURO Thu, 09/17/2009 - 05:09
I do this. It works ok without encription, only mgre+nhrp. I found a new problem. How to create the crypto maps unknowing the remote address (the spoke is a dynamic ip).
Marcelo
Correct Answer
paolo bevilacqua Thu, 09/17/2009 - 05:12
  • Hall of Fame,
    Founding Member
paolo bevilacqua Thu, 09/17/2009 - 12:23
  • Hall of Fame,
    Founding Member
Very good, thanks for the nice rating and good luck!
