QoS for Voice issue
Sep 15th, 2009
hi,
wich of the 2 policy map can i use for the best practice QoS Voice? and why?
Example 1:
ip access-list extended Voice
permit udp any any range 16384 37276
ip access-list extended Voice-Signaling
permit udp any eq 1718 any
permit udp any any eq 1718
permit udp any eq 1719 any
permit udp any any eq 1719
permit tcp any eq 1720 any
permit tcp any any eq 1720
Class Map:
class-map match-any Voice-Signaling
match access-group name Voice-Signaling
match ip dscp 24
match ip dscp 46
Example 2:
ip access-list extended VOICE
class-map match-all GOLD
match access-group name VOICE
Nicholas Matthews Tue, 09/15/2009 - 21:31
  • Red, 2250 points or more
The difference between the two is whether or not you would like to give different treatment between your media and signaling.
All the design guides you will read will tell you to do something similar to LLQ for voice. Priority queue the media, and give a certain percentage of bandwidth to the signaling.
In all practicality, if you give priority to both you probably won't notice any difference since the signaling is a relatively low value compared to the media anyways.
Ex 1: correct
Ex 2: will work, but not as correct
-nick
