unity silly question number 650101
Sep 15th, 2009
Is there a way in unity to separate tenants. I know I can have separate call handlers and the rest. but can you divide up the directory so they are unknown to each other.
Rob Huffman Wed, 09/16/2009 - 06:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bill,
Not silly at all my friend. Have you looked into this setup?
Partitioning Subscriber Accounts for Message Addressing by
Phone
Cisco Unity allows you to partition subscriber accounts into separate groups to restrict who they can
address messages to and who they can add to distribution lists, when they do so by phone.
To partition accounts, you define message addressing search scopes by associating subscribers with
directory handlers.
Partitioning Subscriber Accounts for Message Addressing by Phone
By default, search scopes are defined for the system by the addressing option settings for the primary
location that is configured for the Cisco Unity server. The option settings allow you to restrict message
addressing to the global directory (all subscribers), to all subscribers in a dialing domain, or to all
subscribers on the local Cisco Unity server.
When you associate subscribers with directory handlers, you can have Cisco Unity restrict their message
addressing search scopes to the search option that is selected for the directory handler. The search option
specified can be a dialing domain, the local Cisco Unity server, a location, a class of service or a public
distribution list.
This can be useful for setting up a multi-tenant system where there is a need to prevent subscribers in
one group from sending messages to subscribers in another group.
For example, if your organization needs to partition subscriber accounts into two groups such that
subscribers in each group cannot address messages to subscribers in the other group, do the following
tasks in order:
1. Create a separate class of service for each group.
2. Create a separate directory handler for each group for which the Search In options are set to a
different one of the two classes of service that you created in task 1.
3. Create separate subscriber templates, and associate each template with a different one of the two
directory handlers that you created in task 2.
4. Use the two templates to create the two groups of subscribers.
Note Changes to settings in a template do not affect any existing subscriber accounts that were based on that
template. After you create subscribers, you cannot use a template to modify them.
Alternatively, if the subscriber accounts already exist and are members of separate public distribution
lists, you can associate a different directory handler with each distribution list, then use the Bulk Edit
utility to associate each group of subscribers with the applicable directory handler.
https://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/administration/guide/ex/5xcusag210e.pdf
Hope this helps!
Rob
