configure CME for remote sites to have mailboxes
Sep 15th, 2009
Some months ago I found a pdf document where is given an example of how to configure CME for central site with unity express in order to support mailboxes for some remote sites
Any of you have the link so that I can download the pdf file??
regards
Overall Rating: 4.5 (4 ratings)
Rob Huffman Wed, 09/16/2009 - 06:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey brandon,
Good find buddy!+5 points from here.
I believe this restriction has been lifted with CUE 3.2;
Here is the "old" info;
Cisco Unity Express must be installed on each Cisco CME host router. Cisco Unity Express cannot provide voice-mail services across Cisco CME routers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/integration/unity_exp/configuration/guide/cue_cme1.html
Here is the new info;
Q. What are the new features introduced with Cisco Unity Express 3.2?
A. Cisco Unity Express 3.2 introduces the following enhancements:
• Integration with multiple Cisco Unified Communications Manager Express sites: Cisco Unity Express (on NME-CUE only) can integrate with up to 10 Cisco Unified Communications Manager Express remote sites. This solution allows centralized voicemail and Automated-Attendant features for up to 10 sites when voicemail at each remote site branch is not essential and there is a small number of users at each site.
Q. Which releases of Cisco Unified Communications Manager Express will be supported with Cisco Unity Express Release 3.2?
A. Cisco Unity Express **will be supported with Cisco Unified Communications Manager Express Releases 4.0, 4.1, 4.2, and 4.3.
Cisco Unity Express Release Notes
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_notes_list.html
Hope this helps!
Rob
Brandon Buffin Wed, 09/16/2009 - 06:48
  • Purple, 4500 points or more
Great information, Rob. Thanks for the clarification.
Brandon
