Cisco and Dell STP interop
Sep 15th, 2009
Hi Guys,
I have been searching around a little on the Cisco and Dell STP interoperability. Doesnt seem to have a concrete answer.
I have a Cisco CAT6500 running Rapid PVST and a Dell Powerconnect 3548. I was wondering how the Dell P3548 STP must be done to interop with Cisco Rapid PVST successfully.
Any help will be much appreciated.
platinum_jem Wed, 09/16/2009 - 05:38
I'm referring to Spanning tree here where the spanning tree interop extend to the Dell switches to prevent looping conditions when redundant links are connected.
The URL link only shows the VTP interop, not for spanning tree.
Any help there ?
John Blakley Wed, 09/16/2009 - 05:44
  • Purple, 4500 points or more
I don't know Dell's stance on it, but we run RSTP here. I have a Cisco 3750 in a stack for my core, and we run Powerconnect 3548s as edge switches. They work fine.
HTH,
John
platinum_jem Wed, 09/16/2009 - 05:58
Do you have a redundant links or loop conditions for your Cisco to Dell switch connection ?
I'm looking to create a redundant or Mesh infrastructure, so STP is critical for handling looping conditions.
John Blakley Wed, 09/16/2009 - 06:38
Yes I do. I have a stack of 7 3548s on a floor below me with 1/g1 and 7/g1 connected to the core switch, and I have another stack on my floor of 6 switches with 1/g1 and 7/g1 connected to the core. On a weekend, I pulled the active connection from the Dell and it failed over to the redundant link on the 3750.
HTH,
John
