CUCM 7.0
Sep 15th, 2009
Hii Experts,,
If i have a cluster of cucm 7.0 and ccm 4.1 and there is a trunk btween them, if want to upgrade the ccm 4.1 to 7.0 and want to but them in one cluster is there is away to merge between the two DB will the DMA will help to merg or only to take the windows base DB to linux base DB.
Regards..
Jaime Valencia Wed, 09/16/2009 - 15:11
There is no way to merge other than taking what's possible with BAT, tweak the files to accommodate the CUCM new format (mandatory fields, new configs needed, etc) and import them
DMA is to migrate a cluster, not a consolidation tool. Also the DMA tar file is only used during INSTALL, once a server it's installed the file is useless.
java
if this helps, please rate
