remove key learned fron detector in Guard.
Sep 15th, 2009
hi..
I don't know How can I remove the key learned by detector for ssh connection in guard
for example.
the guard configuration likes below:
key add riverhead ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEAyzTYvkwZzJPl9qkF4tBRHxNNAiYqKJQ6M1wV4Lp9V6QhdJ/JNw/zoyZfnXnivQV7gm83Q+4iebrEu86fu7yUV4vWBVBxpplfe6t7BBh7IRhK4Cy9rtTiz3b/qWaxiqRKfvntXBVVE4SzXYPdzCrd+0svxEubejJvYq4hIv6jZ2zY0QxbSVlY249stuMAoD90/GFeEUJGI6S3PhuW96nRJqFMcZ8tsRpzwKn7PDvDRFJFXodKCgDhPsn9mZb2U0Sty9lqWbC4DFZQ5rlxj5SjLWsoay3khhEzzlvNRuM9zRbMlx0hMMzuI1BWlAAKRoM2M7LJZ7iCJmOzGDwOwZMEHw== [email protected]
There are 4 key from detector in Guard. So I want to remove a specific key.
How can I do that?
I tried "no key remove" "no host-key" It seems to be not. In my think, There are a command for removing the key
The sevral key caused the complicated configuration in guard.
Please help me!
