IP phones with AS5300/AS5350
Sep 15th, 2009
Is it possible to connect directly my IP phones directly to an AS5300/AS5350 ( having only a switch in between). If so, do I connect them just like i would to an ISR router?
Overall Rating: 4 (1 ratings)
Nicholas Matthews Wed, 09/16/2009 - 04:51
Yes, you can do this. The AS5300 is a router just like any other. The only difference is you won't be running CME on the AS5xxx platforms like you might be on an ISR.
-nick
