Can I remove "call-home" setting on Cat6500?
Answered Question
Sep 15th, 2009
  • Bronze, 100 points or more
Hello everyone,
I want to remove the following "call-home" setting from configuration (NVRAM) or stop it from showing by show runn command on Cat6500 12.2(33)SXH4.
Is it possible or I can't remove it?
If possible, could you please let me know how can do it.
call-home
alert-group configuration
alert-group diagnostic
alert-group environment
alert-group inventory
alert-group syslog
profile "CiscoTAC-1"
no active
no destination transport-method http
destination transport-method email
destination address email [email protected]
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
subscribe-to-alert-group diagnostic severity minor
subscribe-to-alert-group environment severity minor
subscribe-to-alert-group syslog severity major pattern ".*"
subscribe-to-alert-group configuration periodic monthly 26 14:24
subscribe-to-alert-group inventory periodic monthly 26 14:09
I understand the default setting of Call Home feature is disabled, but I want to remove it.
Thanks and regards,
Shinichi
Correct Answer by Lucien Avramov about 7 years 6 months ago
Smart Call Home should be disabled by default.
The global config command 'service call-home' enables it. It's available from 12.2(33)SXH
No service call-home will disable it, however the actual call-home block cannot be removed from the configuration.
Here is a good call home configuration link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/con
figuration/guide/callhome.html#wp1119728
Overall Rating: 5 (1 ratings)
Correct Answer
Lucien Avramov Wed, 09/16/2009 - 00:24
  • Red, 2250 points or more
snakayama Wed, 09/16/2009 - 00:31
Thank you very much for your reply.
I understand it.
Thanks and regards,
Senthil Rajendra Thu, 04/15/2010 - 00:04
Hi Snakayama,
How u removed the Cisco Call Home configuration in the NVRAM..
I tried but only the service was disabled..
Let me Know ..
Thnks&Rgds
Senthil
snakayama Thu, 04/15/2010 - 00:22
Hi Senthil,
I could not remove Call Home setting so Call Home setting is still existing in the NVRAM ...
Shinichi
