Access Inside interface from Outside
snarayanaraju
Level 4
Level 4
Hi Experts,
I request your help in clarifying the scenario below in FWSM:
I want to access my INSIDE interface (ip address 10.1.1.1) from a server located in OUTSIDE interface (ip address 218.248.17.116).
I learned that it is not by default possible in FWSM to access an another interface (INSIDE) from one zone (OUTSIDE).
Is this possible to achieve if I configure IPSEC VPN in FWSM
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 group 2
isakmp policy 1 hash sha
isakmp enable OUTSIDE
crypto ipsec tran-set vpn esp-3des esp-sha-hmac
isakmp key SAIRAM address 218.248.17.116
access-list TUNNEL extended permit ip host 218.248.17.1 218.248.17.1 255.255.255.0
crypto map telnet_tunnel 2 ipsec-isakmp
crypto map telnet_tunnel 1 match address TUNNEL
crypto map telnet_tunnel 1 set peer 218.248.17.1
crypto map telnet_tunnel 1 set transform-set vpn
crypto map telnet_tunnel interface outside
telnet 218.248.17.0 255.255.255.0 OUTSIDE
Please share your valuable ideas .
THANKS IN ADVANCE
sairam
Jon Marshall
Sairam
Have a look at the "management-access" command which allows you to designate an interface that can be connected to from another zone -
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/command/reference/m.html#wp1637044
Jon
Hi Marshall,
Thanks for your ideas and suggestions.The link your provided is very helpful.
So, My requirement is also the same. I have a PRIMARY SNMP server in INSIDE zone and SECONDARY SNMP server in the OUTSIDE zone.
Since both the SNMP server should be configured with the same IP address of the , I should be able to reach the INSIDE interface IP address from the OUTSIDE zone.
Hope this configuration should work for my scenario
sairam
