Cisco VPN Client-EZVPN Split Tunnel
Sep 16th, 2009
Hi I have been trying to configure a VPN Tunnel with Split Tunneling between a PC with Cisco VPN Client and a 1760 Router.
I have been using the document at the following link as a guide:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080235197.shtml
I have followed most of the guide and actually got a tunnel up and running but I had to remove the "match address 199" statement from the "crypto dynamic-map DYNMAP 10", if I leave it in it will not establish a tunnel at all, without it the tunnel is established and seems to work fine. Is this command required?
Also the command "crypto ipsec profile greprotect" doesn't appear to do anything nor do the access-lists 101 and 111 so I've removed them from my configuration.
I am using c1700-adventerprisek9-mz.124-25a.bin on the router and VPN Client 5.0.01.0600.
