Call Manager Enet Interfaces
mcecilia
Hello All,
Call Manager on MC7845 have two ethernet interfaces.
How does both work? Active/Standby , Load Balanced / Etherchannel.
Can one have 1gb speed and the other 100Mpbs.
Many thaks
Should not be changed, it is the best way for redundancy so you can connect to two switches.
paolo bevilacqua
Which CM version ?
Sorry. Using CM 6 and planning CM 7.
I have found the command "set network failover enable" that makes a team between enets interfaces in a active/standby configuration, migrating the licensed mac from one interface to the other in a failover. But, do not know if this behaviour or configuration can be changed.
