Voice VLAN
Kevin Brennan
Hi All,
I'm having a litle difficulty with setting up a (working) voice VLAN on a Cat 2960-24PC using Avaya 9630 phones.
My port config is:
interface FastEthernet0/12
description ### VOIP Test ###
switchport access vlan 211
switchport mode access
switchport voice vlan 213
srr-queue bandwidth shape 10 0 0 0
mls qos trust dscp
spanning-tree portfast
end
The phone powers up no problem, but then sits waiting for DHCP and VLAN info.
If I configure the port without the voice vlan it works, in that the phone gets a DHCP ip address (as expected really, but this proves DHCP and trunking from my switch to router is working) config below.
switchport access vlan 213
end
Router on a stick config
interface FastEthernet0/1.213
description ### To XXX Voice ###
encapsulation dot1Q 213
ip address 172.21.3.1 255.255.255.0
ip helper-address 172.21.1.10
ip nat inside
ip virtual-reassembly
zone-member security Inside
ip tcp adjust-mss 1412
My setup is a a 1841 configured as a router on a stick with VLANs 1,211,212 and 213 trunked to the 2960. Sh int trunk confirms that this is working. Putting a Windows XP DHCP client onto VLAN 213 proves that the IP Helper on the subinterface on the 1841 is working.
I have setup a debug ip packet on the router (with an ACL) to see if there is any DHCP type traffic with the voice vlan configured and I can't see any.
I have the same config on my Cat6509-E's on a different site and they all work perfectly with the first config.
Any suggestions?
Kevin
rays
Hello Kevin.. Not sure if you got this resolved or not but basically when the Avaya phone is connected initially it has no idea what vlan it is connected to. It sends a DHCP request, which the helper forwards to the dhcp server. The dhcp server should be configured with option 242 (under the data vlan scope options) which is used to provide the phone with its correct VLAN ID. The Avaya phone recieves the response and then then sends another DHCP request, this time using the correct VLAN ID.
It could be that the DHCP server you are using is not setup correctly with option 242, therefore the phone does not know to tag its traffic with VLAN ID 213.
Also, the Avaya phone (afaik) by default sets the COS value to 6. You may want to trust COS (not DSCP) on the access port and re-mark the COS to value 5.
Let me know if this helps
Ray
10 Replies 10
Giuseppe Larosa
Hello Kevin,
the standard configuration with voice vlan is for Cisco IP phones that exchange CDP messages with the switch port.
You should look for the standards based LLDP to play the role of CDP on your device.
Or you dedicate the port to the phone using access vlan=213 but this means no pc downstream the avayas phone.
see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2960/software/release/12.2_50_se/configuration/guide/swlldp.html
or
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_50_se/configuration/guide/swlldp.html
the chapter about LLDP in config guide.
you may need an IOS upgrade on your device to support it.
Hope to help
Giuseppe
Hi Giuseppe,
Thank you for your reply, I will read up on LLDP.
I'm still confused though as to why this same config works on 6509-E's on a different site. LLDP is not enabled on them.
Kevin
Edison Ortiz
Kevin,
ip nat inside
What's being translated?
How is your zone security configured?
It can potentially affected the phone from getting its information from TFTP after getting its IP from the data Vlan.
__
Edison.
Hi Edison,
That was me being lazy and doing a copy and paste from sub-if fa 0/1.211 (Which has access to the internet via a NAT pool)
I've cleaned up the config, it now is:
rays
Ray
rays
Ray
Hi Ray,
You steered me in the right direction!
I have made a mistake with the L2QVLAN and PHY2VLAN tags on the DHCP server.
Thank you!
For information, the final working config on the switchport was
mls qos trust dscp
and on the DHCP server I needed the following in option 242 along with the MCIP. "L2Q=1,L2QVLAN=213,PHY2VLAN=211"
In summary it was an Avaya problem rather than a Cisco one.
Thanks all, this really is a great forum.
Cheers
Kevin
Hello Ray,
very good note so there is an alternate way to communicate vlan-id to avaya phone at the DHCP level.
good to know
Best Regards
Giuseppe
No problem guys, i use this forum quite a lot for obtaining information, its good to provide some for a change!
Ray
rays
Ray
