Cluster Configuration - Backup&Restore
Sep 16th, 2009
is there any comfortable function in the cluster CLI to backup or restore a configuration?
show configuration all > ftp://user:pass@host would do it for backup - but to copy and paste all the text from the backup file doesn't seems to be as comfortable as I'm used to from the Catalyst switches.
cco-iamrodos Fri, 09/18/2009 - 02:59
There are multiple ways to do this. One is via the GUI, check Chapter 31 in the GUI guide. The other way is via the CLI using the "create backup" command.
Both of these can use an FTP or SFTP as the destinateion.
Let me know if you want some screen shots.
