paolo bevilacqua Wed, 09/16/2009 - 12:38
  • Hall of Fame,
    Founding Member
Hase you got the right time in the router ?
Have you reset telephones ?
mohamedessoufy Wed, 09/16/2009 - 12:42
Yes, i get time-zon 23 (West Europe), i see that the time-zone is well configured on 23 with the show telephony-service command.
i reset phones too.
paolo bevilacqua Wed, 09/16/2009 - 12:47
  • Hall of Fame,
    Founding Member
You need right time in the router, "show clock". Using an NYP server is the preferred form.
mohamedessoufy Wed, 09/16/2009 - 12:50
with "show clock" i have the correct time in the router, ntp server is configured too.
Adrian Saavedra Wed, 09/16/2009 - 13:01
  • Gold, 750 points or more
If correct time is in the router and time-zone under telephony service, then you can try:
telephony-service
create cnf-files
Then reset the phones.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
mohamedessoufy Wed, 09/16/2009 - 13:04
I tried that too but don't resolve the problem.
thanks for your help
paolo bevilacqua Wed, 09/16/2009 - 14:51
  • Hall of Fame,
    Founding Member
Have you set right type under ephone ?
paolo bevilacqua Thu, 09/17/2009 - 01:03
  • Hall of Fame,
    Founding Member
23 in telephony-service.
Have you checked router have the right time in first place ?
mohamedessoufy Thu, 09/17/2009 - 01:35
23 that's the value i enter.
yes the router has the right time and ntp server configured too.
paolo bevilacqua Thu, 09/17/2009 - 01:47
  • Hall of Fame,
    Founding Member
Which telephone do you have and which firmware ?
paolo bevilacqua Thu, 09/17/2009 - 02:09
  • Hall of Fame,
    Founding Member
Try upgrading to 8.4(4)
mohamedessoufy Thu, 09/17/2009 - 05:29
I reloaded the router and that's work fine now, thanks for your assistance
ISIDOROS ANTONIOU Fri, 07/19/2013 - 04:02
Hi to all,
I have read all your helpful notes. I need your help on the this problem.
The CME has the below configuration:
clock timezone EET 2
clock summer-time EEST recurring last Sun Mar 3:00 last Sun Oct 4:00
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
telephony-service
time-zone 29
time-format 24
date-format dd-mm-yy
All the IP-Phones 6941 has the correct time but unfortunately all the 79xx IP-Phones have wrong time (missing one hour).
Could you please help me on this?
tnx a lot
Isidoros
