Monitor inter-vlan traffic only?
Sep 16th, 2009
Can just the L3 traffic that flows between VLANs (not within them) be monitored/mirrored in a 3750 switch or similar? How would you set it up?
Thanks.
Overall Rating: 5 (2 ratings)
deyadav Thu, 09/17/2009 - 00:19
  • Cisco Employee,
As far as I understand, there is no way to get this done over 3750. The routed traffic across Vlan's could only be monitored using Netflow which is not an available option on 3750.
It could be achieved on 4500's with Supervisor's installed with Netflow Daughter card or with 6500.
For 4500 refer to this:
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K14682540
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/nfswitch.html
For 6500:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml
Deepak Yadav
pnicolette Thu, 09/17/2009 - 09:03
Thanks, Deepak. Any idea if it can be done using VLAN ACL capture?
Giuseppe Larosa Thu, 09/17/2009 - 12:14
  • Hall of Fame,
    Founding Member
Hello Paul,
this would be a good idea.
unfortunately command reference for 12.2(44)SE shows that the action command supports only forward or drop option I don't see a capture option
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/command/reference/cli1.html#wp9751857
Hope to help
Giuseppe
deyadav Thu, 09/17/2009 - 22:45
  • Cisco Employee,
Hi Paul,
VACL capturing is a good option on cat6k platforms, unfortunately it's not supported on 3750 and other 3K switches.
For the above link there is a documentation bug filed: CSCta66401
"Cisco Catalyst Switch Guide lists VACL Capture as supported on 3750/3560"
Although it does not have any documented Release notes, however I can confirm that it is on the same document.
I searched a lot, however was not able to find any option for 3750 platform.
