Failed to create computer account for NTLM realm
Sep 16th, 2009
I'm getting error while trying to create NTLM realm on my device. Windows 2008 R2 Native is my domain functionality level.
Two days ago, I've managed to create NTLM realm in old Windows 2003 Native domain.
What could be the problem?
Error  — Computer Account creation failed.
Failure: Error while joining WSA onto server '172.16.20.30' : Failed to join domain: Improperly formed account name
khoanguy Fri, 09/18/2009 - 18:22
Assuming you are using Async OS 6.0 and above which support AD 2008.
Check to make sure the Ironport hostnam is not already in the "Computers" OU first before re-joining.
If you are still seeing erorrs, try to use:
username password
instead of:
DOMAIN\username password
borism.teched Mon, 09/21/2009 - 08:33
I was using AsincOS 5.7 :) Everything worked well awfer upgrade to 6.3.
