setup routing in a ASA
Answered Question
Sep 16th, 2009
I have a ASA 5520, how do I set up a static route to route traffic to a router, I have 10.9.1.0/16 on the ASA which my users are on, on the router I have 192.168.0.0/16, how do I set to ASA to route to the router for the 192.168.0.0 network?
Correct Answer by Collin Clark about 7 years 10 months ago
You've corrected enough of mine, so I'm just returning the favor! The only reason for the green star is that it's been a little slow so I've had more NetPro time.
Correct Answer by Jon Marshall about 7 years 10 months ago
Shane
Assuming 192.168.0.0/16 is on the inside of the ASA and the next hop from the ASA ie. the router is 192.168.0.1
route inside 192.168.0.0 255.255.0.0 192.168.0.1
Jon
Overall Rating: 5 (3 ratings)
Correct Answer
Jon Marshall Thu, 09/17/2009 - 00:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Shane
Jon
Collin Clark Thu, 09/17/2009 - 05:52
  • Purple, 4500 points or more
A slight modification to Jon's post-
The last IP in the configuration Jon posted is where the ASA should send packets to to get to the 192.168.0.0 network. It should be an address from 10.9.0.0 network.
Jon Marshall Thu, 09/17/2009 - 08:05
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Oops, thanks for correcting my mistake :-)
And belated congrats for the green star !
Correct Answer
Collin Clark Thu, 09/17/2009 - 08:10
shanemcanuff Thu, 09/17/2009 - 14:49
So since the 192.168.0.0 is 255.255.254.0 and the ASA is 10.9.1.0 255.255.0.0 is this right
route inside 192.168.0.0 255.255.0.0 10.9.1.4
Jon Marshall Fri, 09/18/2009 - 00:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Shane
If 10.9.1.4 is the IP address of one of the router interfaces then yes that would work.
Jon
