Call Handler: Send caller to (Caller input)
Answered Question
Sep 16th, 2009
I am in the process of making a call handler and i have few questions.
I need to have the call to be transfer to an external number or an internal ext. with no mailbox (not a unity subs)
Can we do this since the only transfer option is only to a subscriber?
in my understanding, A subscriber is a user in the unity, has a voicemailbox.
Do i need to make another call handler for transferring to an internal ext.? but i would not be able to transfer it to an external number.
Thank you,
Overall Rating: 5 (1 ratings)
sienz.sienz Wed, 09/16/2009 - 15:58
Brad, It works for internal number.
How about transferring to an external number?
Can we do that or it will just create a security risk and no option for this?
Bradford Magnani Wed, 09/16/2009 - 16:39
Yes, you can transfer to external numbers, but you are correct, it can pose a security risk if you're not careful. You'll need to ensure your CS_Default_System_Transfer restriction table only allows the numbers you're allowing users to dial to reach external #'s.
•Caller System Transfer-Sends the call to a conversation that allows callers to transfer to a number that they specify. For example, callers may want to dial a lobby or conference room phone that is not associated with a Cisco Unity subscriber. Cisco Unity performs the transfer only when the CS_Default_System_Transfer restriction table permits it.
