Warning message
Joe Clarke Thu, 09/17/2009 - 07:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to make sure you have CS 3.0.6, RME 4.0.6, Campus 4.0.13, and DFM 2.0.13. Then, go to Common Services > Software Center > Device Update, check Common Services and Resource Manager Essentials, and download and install all available updates.
MathieuJM_2 Thu, 09/17/2009 - 07:55
Here are the version number:
CiscoWorks Common Services : 3.0.5
Campus Manager : 4.0.6
CiscoView : 6.1.5
Device Fault Manager : 2.0.6
Internet Performance Monitor : 2.6.0
Integration Utility : 1.6.0
Resource Manager Essentials : 4.0.5
So definitively we need to upgrade the installed version.
Are all the version you mention available on LMS 2.6 ?
