Solution for Gateway webcontent filtering/Antivirus/Antispam/Malware
Sep 17th, 2009
HI All,
I am looking for a solution that can do all the Gateway webcontent filtering/Antivirus/Antispam/Malware functions. This solution will be used for 300 employees. Any good cisco or non-cisco sloution name will be more helpfull that should be cost effictive as well.
courtnash Mon, 02/15/2010 - 09:11
Do you really like Ironport?  I think it still needs development....
courtnash Mon, 02/15/2010 - 09:10
Palo Alto Firewall is a good solution.... We are aCisco shop but the ironport isn't all that night for user access. It uses a really slow reporting tool Sawmill.  Cisco really needs to work like these guys... I've eval'd and it was awesome but we're a state agency and Cisco is easy and fast to purchase..
http://www.paloaltonetworks.com/products/index.html
