Registration problem with SIP 3911
mariapenilla
I used in the configuration the following commands:
ip dhcp pool sip_3911
host 172.17.6.118 255.255.0.0
client-identifier 0100.1aa1.1b97.14
default-router 172.17.1.1
option 150 ip 172.17.1.1
tftp-server flash:SIP3951.8-1-1b.loads
tftp-server flash:SIP3951.8-1-1-4.zz
tftp-server flash:DSP3951.0-0-0-2.zz
tftp-server flash:BOOT3951.0-0-0-9.zz
voice service voip
allow-connections sip to sip
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 172.17.1.1 port 5060
max-dn 20
max-pool 10
load 3911 SIP3951.8-1-1b
authenticate register
tftp-path flash:
create profile
dialplan-pattern 1 ... extension-length 3
voice register dn 1
name SIP_Phone
label SIP_3911
number 391
call-forward b2bua noan 15000 timeout 20
call-forward b2bua busy 15000 timeout 20
allow watch
voice register pool 1
id mac 001a.a11b.9714
type 3911
number 1 dn 1
dtmf-relay sip-notify
codec g711ulaw
username user1 password Cisco
As i pick up the phone I get a busy number. The phone seems that has the right parameters, SIP configuration: number, name and authentication name, correctly loaded its firmware and got ip address but is not registered, this could be an authentication problem but it doesn't seem so due to the authentication register and user and password are correctly been set.
17 Replies 17
paolo bevilacqua
Take "debug ccsip message" with "term mon".
also add 'debug tftp events' please
I hope with this you could give me a hint to solve this problem.
Really appreciated.
Best regards.
Really appreciated.
Best regards.
Please take "debug ccsip messages" and "debug tftp events" after your turn on the phone. Do not enable any other debugs.
The only logs that i get with both debug enabled are the following:
015291: Sep 17 15:39:08.369: TFTP: Looking for SEP001AA11B9714.cnf.xml
015292: Sep 17 15:39:08.373: TFTP: Opened flash:/SEP001AA11B9714.cnf.xml, fd 0, size 2924 for proce
015293: Sep 17 15:39:08.385: TFTP: Finished flash:/SEP001AA11B9714.cnf.xml, time 00:00:00 for proce
015294: Sep 17 15:39:09.033: TFTP: Looking for SIP3951.8-1-2-13.loads
015295: Sep 17 15:39:09.521: TFTP: Looking for Spanish_Spain/ld-sip.jar
Even though I am a bit confused because i change the simple value of number or try to change the firmware just in case i had it wrong and it keeps displaying on the phone the old data.
You sure it's a 3911? It's asking for a 3951 firmware file.
-nick
You should know on the cme they have set to be called in the same way.
Check SEP001AA11B9714.cnf.xml what contais as phoneload ?
perhaps delete and generate it again.
For SIP phones on CME, after any config changes you make, you need to do execute 'create profile' under the voice register global, this will build the config files again. Unlike Skinny phones, for SIP phones you have to do it everytime to update the profile.
Also, can you provide the following output
show voice register global tftp-binding
thanks,
Hi Parshah,
Here u have the sh you asked me for:
CME-Telenor#sh voice register tftp-bind
tftp-server syncinfo.xml url flash:/syncinfo.xml
tftp-server SIPDefault.cnf url flash:/SIPDefault.cnf
tftp-server softkeyDefault_kpml.xml url flash:/softkeyDefault_kpml.xml
tftp-server softkeyDefault.xml url flash:/softkeyDefault.xml
tftp-server SEP001AA11B9714.cnf.xml url flash:/SEP001AA11B9714.cnf.xml
CME-Telenor#sh voice register all
VOICE REGISTER GLOBAL
CONFIG [Version=7.1]
Version 7.1
Mode is cme
Max-pool is 10
Max-dn is 20
Outbound-proxy is enabled and will use global configured value
Source-address is 172.17.1.1 port 5060
Load 3911 is SIP3951.8-1-1b
Authenticate register
Authenticate realm cisco.com
Time-format is 12
Date-format is D/M/Y
Time-zone is 23
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Dialplan 1 ... extension-length 3
Forwarding local is enabled
Privacy is enabled
Privacy-on-hold is disabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:
Generate text file is disabled
Tftp files are created, current syncinfo 0011421007459543
OS79XX.TXT is created.
timeout interdigit 10
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
VOICE REGISTER DN
Dn Tag 1
Config:
Number is 392
Preference is 0
Huntstop is disabled
Name 392
Allow watch is enabled
Auto answer is disabled
Label is 392
VOICE REGISTER TEMPLATE
VOICE REGISTER DIALPLAN
VOICE REGISTER POOL
Pool Tag 1
Config:
Mac address is 001A.A11B.9714
Type is 3911
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
DTMF Relay is enabled, sip-notify
Call Waiting is enabled
DnD is disabled
Busy trigger per button value is 0
keep-conference is enabled
username user1 password cisco
Transport type is udp
service-control mechanism is not supported
Privacy feature is not configured.
Privacy button is disabled
Dialpeers created:
Statistics:
Active registrations : 0
Total SIP phones registered: 0
Total Registration Statistics
Registration requests : 0
Registration success : 0
Registration failed : 0
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
I have checked the .cnf.xml and seems everything correct. I have deleted and generated it again.
Reloaded the phone and it gets the name, number and firmware correctly but there is no way to get it registered.
Can you take debug ccsipemessage please.
Seems that debug ccsip messages doesn't give any kind of messages.
I have taken as well debug tftp events:
CME-Telenor#debug ccsip messages
SIP Call messages tracing is enabled
CME-Telenor#debug tftp
CME-Telenor#debug tftp events
TFTP Event debugging is on
CME-Telenor#
004051: Sep 21 14:27:15.526: TFTP: Looking for SEP001AA11B9714.cnf.xml
004052: Sep 21 14:27:15.666: TFTP: Opened flash:/SEP001AA11B9714.cnf.xml, fd 0,
size 2937 for process 76
004053: Sep 21 14:27:15.682: TFTP: Finished flash:/SEP001AA11B9714.cnf.xml, time
00:00:00 for process 76
004054: Sep 21 14:27:16.334: TFTP: Looking for SIP3951.8-1-1b.loads
004055: Sep 21 14:27:16.446: TFTP: Opened flash:SIP3951.8-1-1b.loads, fd 0, size
59 for process 76
004056: Sep 21 14:27:16.446: TFTP: Finished flash:SIP3951.8-1-1b.loads, time 00:
004057: Sep 21 14:27:16.882: TFTP: Looking for .xml
004058: Sep 21 14:27:17.362: TFTP: Looking for English_United_States/ld-sip.jar
I have no idea what .xml stands for and neither English_United_States/ld-sip.jar, where should I get them from?
On the phone i have number, name and authentication name well taken. There is no vlan created and is using the default one.
