overlapping local network-lists
Sep 17th, 2009
Hello;
We configured a new VPN tunnel on our VPN concentrator 3005. Local IP address for this tunnel 10.0.0.100/32 and we named this as X_local. There was another network-list names as Y_local which also has 10.0.0.100/32. After we configured the new tunnel, the old tunnel become problematic. 10.0.0.100 couldn't reach remote network and the old tunnel didn't become UP. We logged out from the new tunnel then the old one started working. Now two of them are working. However i think we should know reason of this problem for a better workaround. Anyone knows reason???
Add-on: The old one becomes UP, but we have to wait for a while(10-20 ping timeouts). When we log out the new one, it becomes UP after one timeout.
ggilbert Thu, 09/17/2009 - 08:36
  • Cisco Employee,
On the VPN concentrator, you can use the same network list "X-Local" for the new tunnel as well. If you use that, does it have any issues.
Gilbert
ozgurguler Thu, 09/17/2009 - 21:57
Yes, i tried it.
I think there is a bug. i will upgrade it.
