Custom State Condition in CSA 6.0.1
Sep 17th, 2009
  • Gold, 750 points or more
Has anyone used these state conditions called Custom1-9 ? I can't figure out how to disable them again after using them, so if i set a rule to enable Custom1 i can't find any way of disabling them again.
pradeepde Wed, 09/23/2009 - 14:22
  • Bronze, 100 points or more
The CSA MC lets you centrally reset agent settings back to their original states and clears all user-configured settings. You may want to do this in order to clear cached user query responses or to reset system states.
Resetting Cisco Security Agents does not clear configured Firewall Settings or File Protection settings. But if Firewall Settings or File Protection settings are enabled, they are disabled after a reset as this is the default factory setting. The information entered into the edit boxes for these features is not lost.
http://www.cisco.com/en/US/docs/security/csa/csa601/user_guide/Rule_Modules.html#wp1240410
jan.nielsen Thu, 09/24/2009 - 15:01
I know about that, what i am asking is if there is a rule type that i could use to reset the custom state i enabled with the Set state rule.
