Sip trunk config issues
Sep 17th, 2009
I'm using a unified 500 to configure a sip trunk via the configuration assistant application.
I get no incoming calling or outgoing calling but when I do a 'debug ccsip message' I can see the incoming call hitting the router. I have attached this output in the attachment 'log-dial-in'.
Any pointers greatly appreciated
Nicholas Matthews Thu, 09/17/2009 - 07:02
Hi Craig,
I would make sure that the ACL in this configuration:
voice source-group CCA_SIP_SOURCE_GROUP
access-list 2
translation-profile incoming SIP_Incoming
It needs to be accurate, otherwise you will have this behavior. From the looks of it, you have but the invite comes from
craig.corbett Thu, 09/17/2009 - 07:07
Hi, I have checked and I'm sure it is correct. The 114 address is the system. When I call the number I get the info in the debug.
